Gellien
Posté le: 15 Nov 2014 03:34 Sujet du message: Manual car flameout troubleshooting methods |
1, high-standard quality of qualified fuel.
2, a thorough cleaning of the oil line will include fuel injectors, throttle, fuel tank and so on. There may be you add oil quality tests, mastic too much, the oil passage blocked, the attack caused by poor oil. Automotive repair and maintenance network
3. Failure to turn off under car idling state is mainly due to excessive dust in the air, the engine is running at idle motor and the throttle valve plug seat at the deposition has many dirt, when excessive accumulation of dirt, the engine with Fiat connecting rods will be idling too low idle stability is poor, there will be an idling-stop when traveling. Solution to this problem is simple: just wash idle speed motor can.
4, oil is smooth, which can easily lead halfway flameout.
5, the long-term car park is not used. In fact, should not be parked for a long time. In case parked a long time, before re-use should do a thorough maintenance, oil changes, filter, etc., and, where appropriate check fuel circuit. Your vehicle may cause long-term parking is because lubrication or circuit problem. |
